1 members (Otto Skorzeny),
81
Mod | | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61551 06/09/2006 6:03 PM | Joined: Jun 2006 Posts: 18 Apprentice | | Apprentice Joined: Jun 2006 Posts: 18 | I am looking for a straight six to put in my 1950 1/2 ton. I want reliabilty over anything else. What would be the best for me? Can I get a 235 without "babbit" bearings?? What years of motors have the "good" 250's? Any advice would be great. If you know of any for sale in the northwest please let me know. Thank you! | | |
#61552 06/09/2006 6:13 PM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | I am with you, put a 250 or 292 truck engine. if you put a 250 get the one without the manifold built into the head. put a t5 or a 700r and you will have a great driver. if you use a 700r put a powerglide colum shifter to give it the old look. if you put the t5 weld a original 4 speed stick to the t5 to get the old look. | | |
#61553 06/09/2006 6:14 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | For the pure ease of installation, the 235 would be the best. Get one from a '54-'62 (excluding '62 Nova) car or truck. Patrick's or Stovebolt Engine can help with information on the swap. You may consider a 261 as well. It'll bolt up the same as a 235, just has a larger displacement. Welcome aboard the 'Bolt, let us know how it works out on your '50.
Bill Burmeister | | |
#61554 06/09/2006 6:15 PM | Joined: Jun 2006 Posts: 18 Apprentice | | Apprentice Joined: Jun 2006 Posts: 18 | Will a 250 bolt right in? | | |
#61555 06/09/2006 6:33 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A 250 would require mount and other drivetrain mods to fit. It can be done. The question would be how much work do you want to do? If you don't mind doing the changes required to do the 250, by all means go for it. But if you're looking for an easy bolt in that keeps the balance of the original trans/rearend and the original look, then the 235/261 is the one to go with. Do some more research on the links page before you decide what to do, that way you will know what you'll need for either engine.
#61556 06/09/2006 8:20 PM | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | when the hood is closed and your driving down the freeway a newer 6 will sound the same but with the updated drivetrain you will pass all those close drive trucks icluding the one with 3.55 gears in the rear. | | |
#61557 06/10/2006 7:47 PM | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | I am going with 250 out of a 78 nova a T5 will go behind that.I have found a basic motermount that will put the motor right in my 53'it is avalible at Langdons Stovebolt,and then a basic crossmember mount for the tranny.Other mods include clutch linkage-dosent look to serious,water temp gage cappillary tube is to short-longer ones are available-possible cooling fan clearance problem,I think i will run a electric in front of the raidiator as a pusher. Good Luck Aaron | | |
