3 members (JW51, tesa, Ponchogl), 49 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
I am ready to install wipers now an need to know where the best place to make that buy.
~Jim
Jim Carters,LMC,Bowtiebits,Obschevy dot-com.Any of these and then some should have what you're looking for.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Yeah I've seen them several places. What I needed was a recommendation by some that have bought and installed. How well or hard the installation went; would they make the purchase from a different vendor if they were to need another set.
~Jim
I bought the Newport electric motor.I installed it in my 1951 Chevy 3100,it fit well and works great.I purchased mine from Jim Carters,I think all the vendors handle them.
1951 3100 Chevrolet
As far as installation, I hope you have small hands. I was rewiring my entire truck and replacing the guages at the same time. Take everything out that you can. The radio and speaker grill definitely are in the way.It is a great upgrade though. I used the newport motor and it fit right in. The clips were a bugger though.
PRETENDING IT'S BROKEN SO I CAN PLAY IN THE GARAGE.
Neverdun,will the factory gm radio in an AD fit with the Newport wiper motor in place ?
1951 3100 Chevrolet
havent installed it yet ,but i went with Newport as well,saw an article in Classic Trucks yrs. ago on the install.It looked so simple............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
I've got the Newport in mine. I installed it through the glove box opening with the box itself removed.
I just bought a radio that fits in the original location. Both the speaker opening and the glovebox are open for work area.
I don't have tiny hands but it do have a tiny brain. big_eek
Tim,
People have posted that 47-53 A-D trucks have no problems with after-market electric wiper motors.
However, I think that there is no after-market electric wiper motor that will fit with an original 1954/55 A-D (Chevrolet) radio/speaker. The original GM accessory 2-speed 54/55 6v electric wiper motor works fine with the standard radio. GMC ND 54/55 trucks do not have the same problem with after-market electric wiper motors.
Thanks Tim,I knew that one of them had problems with the original radio fitting.I have an ad radio,but never installed it in my pickup.I figured if i asked the question,it would help big chevy 3600.
I recommend the Newport electric wiper motor.
Thanks,Tim
1951 3100 Chevrolet
Thanks Tim, my new radio isn't as big and take up as much space at the original and hopefully will fit ok.
~Jim
I put an aftermarket radio in min that fits in the factory opening.
Ter Offline
There is a company that I think is called Specialty Power Windows and it also makes power wiper kits. They are a cable operated system and the wiper motor is "remote" located.
If anyone has experience with these I would be interested to hear from you as I am considering them for my truck, a 1951 GMC
