| | | Forums66 Topics128,095 Posts1,056,078 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61529 06/09/2006 12:14 AM | Joined: Jun 2006 Posts: 12 New Guy | | New Guy Joined: Jun 2006 Posts: 12 | I have a 1954 with a 235 engine. I got the engine overhauled 3-4 years ago when a couple valves finally burned up. Since then my oil pressure is low. (It's a long story so bear with me). I worried about it for a while, then after watching the meter drop to "0" after a 20 minute drive I dropped the pan and found the oil pump gasket in parts in the bottom and the oil pump base only loosely attached to the body(held on with a couple threads). I thought I'd found the oil pressure problem. So I fixed that and put in a filter(after market, hung on the firewall, plumbed from the oil pressure fitting and dumping back in at the plug on the front left of the engine.) But the pressure was only a little better. When hot it still dropped to near "0". I started to worry that the year of low pressure hard burned up bearings and that was why my pressure was low. Now it has started making a scraping noise in the engine, a high pitched click, grating. So I checked the valve rockers and they weren't getting oil. There's only a tiny drip coming up to the rocker shaft. Is this right? I have no idea if this is the source of the new noise or not. I was thinking I could just return the oil from the oil filter to the plug on the head that leads to the top end lubrication. Would this work? Should I be worried that this has fried bearings? I have tried to check passages with compessed air and I get almost no flow of air from the back plug under the lifter cover into the block. And there was almost no oil coming out of there when I ran the oil pump with an electric drill. I'd appreciate anyone's experience on this. I took it back to the machinist who did the engine overhaul and he thought the oil pressure was just fine. But he's a young guy. Am I just a nervous nell? | | |
#61530 06/09/2006 12:30 AM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Sounds like something ain't right. There were full pressure and low pressure engines in '54, which is yours?
Did you replace the pump or just the gasket? Did you try the pump with a drill and it didn't work?
If its full pressure, check your gauge and try a different one...
If you still don't have pressure drain the oil and check it out for chunks of metal and pieces of babbit. You might drop the pan and check a bearing or two, and replace the pump.
You should use the holes on the driverside of the block for the filter.
If the pressure is good and you aren't getting oil to the rockers sumtin' wrong.
#61531 06/09/2006 1:56 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | '54 should all be full pressure. I agree with MN51, pull the pan and check the lower end. Sounds like you may also have a blockage in the passage to the rocker arm supply line.
Bill Burmeister | | |
#61532 06/09/2006 5:17 AM | Joined: Jun 2006 Posts: 12 New Guy | | New Guy Joined: Jun 2006 Posts: 12 | Well, I've got oil on my hat and the oil pan off. Oil pump works great. It pushed pressure on the dash gauge to 30 with a drill. But no oil to the lifter side of the engine. I used some compressed air and it seems to be coming out at the rear bearing of the camshaft. Air just bairly came out the oil supply line,(where I took it off the pump) I'm going to put in a thinner gasket in the pump to make ther be less clearance around the impellers(I'm really stretching the hope here). I'm afraid the guy that did the overhaul somehow plugged the oil holes aat that back camshaft bearing. Would that cause this? | | |
#61533 06/09/2006 11:36 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | the camshaft bearings have oil holes in them and must be put in the right position to oil properly. | | |
#61534 06/09/2006 1:20 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Pull the side pan behind the distributer and check the line going from the rear cam bearing to the rocker arm assy. It is a small 1/4 in. copper line about 6 in. long. It is probably plugged up and not feeding oil to the rocker arm assy. Also check the fittings on this line for obstructions. Tom | | |
