3 members (warlock, 6inarow, Otto Skorzeny), 73 guests, and 2 robots.
Topics128,048
Posts1,055,624
#165025 11/30/2006 7:12 PM
Can anyone tell or show me were the capillary tube goes on my 1949 3100 heater control valve??
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
#165026 11/30/2006 9:04 PM
if i recollect,,it screws to the heater housing?
#165027 12/02/2006 1:41 PM
No, it screws to the hump of the firewall pad.
The actual location is obtained thusly:
From the lower left corner of the heater control valve, measure down 2 5/8 inches, and then to the left 2 1/2 inches. That is the exact spot for the screw which goes through the bracket on the end of the capillary tube. You will have excess capillary tube, just loop it nicely around so it looks good and is up out of the way.
This information is from the Chevrolet Acessories Installation Manual, and if you need more information, PM me your email address.
Brian (shop Shark) I'm new to all of this but I just posted that question and while looking around I found your reply. Thank you, thank you so very much. Now I can finish my heater project.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Thanks to all that replyed
Here are a couple of pictures of the Harrison heater with the Ranco Thermostat bulb attached to the firewall pad.
http://www.pbase.com/dennygraham/image/121531022/large
http://www.pbase.com/dennygraham/image/121531024/large
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks for the pictures. It really helps to see them. Steven
Moderated by  ndkid275, Phak1
