0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | Can anyone tell or show me were the capillary tube goes on my 1949 3100 heater control valve??
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | if i recollect,,it screws to the heater housing? | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | No, it screws to the hump of the firewall pad. The actual location is obtained thusly: From the lower left corner of the heater control valve, measure down 2 5/8 inches, and then to the left 2 1/2 inches. That is the exact spot for the screw which goes through the bracket on the end of the capillary tube. You will have excess capillary tube, just loop it nicely around so it looks good and is up out of the way.
This information is from the Chevrolet Acessories Installation Manual, and if you need more information, PM me your email address. | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Brian (shop Shark) I'm new to all of this but I just posted that question and while looking around I found your reply. Thank you, thank you so very much. Now I can finish my heater project. | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thanks to all that replyed | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thanks for the pictures. It really helps to see them. Steven | | |
