1 members (Hotrod Lincoln),
79
0
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | how do i set static timing on my 54 pickup with the inline 6. had to pull the distributor and not sure if i got it back in in the exact spot. it wants to fire but doesnt go ahead and keep running when i release the starter button. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | The best you can do is to put a ohm meter between the wire coming from the points and ground ,after you have the rotor aimed at the # 1 spark plug wire ,and the timming marks lined up ,ball on pointer, also you have to make sure your on the compression stroke of #1 cly.take the plug out and put your finger over the hole when you feel the air pushing on your finger start looking at the pointer and line up the ball.Take the wire off the coil that goes to the dis. put an ohm meter between that wire and a ground ,move the dis. one way and the other untill the points are just opening the ohm meter reads 0 that will get you close enough to start than you can hook up a timing light and set the timming to spec.
Pete | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | were are the timing marks located? i assume on the flywheel. or should i say the dampener on the front of the engine. i can't seem to located them. the truck was running till i pulled the distributor  | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | ok so i guess it maybe located on the flywheel at the rear of the engine. still stumped though
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | The timming marks are on the bell housing and the flywheel there is a hole just to the left of the engine facing the front on the same side as the dis. You'll see the hole in the bell housing and in that hole you'll see a pointer .as you turn the engine over in the right direction you'l see a triangle on the flywheel (TDC)after that you'll see the ball it looks like a ball bearing pressed into the fly wheel when the pointer and the ball are lined up thats your timming mark after you get her running that is what you'll se with the timing light also.
Pete | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | ok i just found it. now if the rotor isn't pointing towards the front or number 1 sparkplug then i need to pull it and reposition it? now it has to be at that mark and having expelled air out the front spark plug hole?? as i've got that one pulled at the moment.. | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | ok i just looked at mine again and it looks like the number 2 then the ball embedded in the flywheel and the the letters iu space then c..?? no triangle
so i line the pointer up with the ball embedded??? | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Yes, line the pointer up with the ball, after being sure the #1 cylinder is on the compression stroke. When you can feel pressure in the cylinder by putting your finger over the #1 plug hole as the engine turns, you're on the right track. Once the ball lines up with the pointer turn the distributor housing clockwise until the points close, then turn it back CCW until they just barely open. If you want to get it exact, use a test light on the distributor primary wire. With the points closed and the ignition switch on, the light will go out. Turn the dizzy housing counterclockwise until the light just comes on, and you'll be timed close enough to start. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think he asked about where the rotor should be pointing. It should be point near the cap terminal that feeds #1 or the front cylinder. The standard position for this wire on the cap is pointing out sideways on the non engine side of the cap. | | | | | Joined: Oct 2009 Posts: 105 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 105 | well when i pulled the distributor to look at it and install a new vacumme advance and put it back in i now i lined it up in the same spot but i had to loosen up things and turn it so that rotor was facing #1 put things back together and she fired right up. now if i could just get it to quite crackly thru the carb when i have it at half throttle and more when i'm going down the road. it doesn't want to hills very well.
in installed one of Tom Langdons holly/weber carbs. doesn't leak like the rochester carb did but can't go very fast without it crackling. guess i will have to email him | | |
