4 members (Otto Skorzeny, Gdads51, Opelika Tom, crenwelge), 75 guests, and 1 robot.
Topics128,062
Posts1,055,851
Members48,428
#615151 01/30/2010 8:15 PM
Is there any harm in adding an external ballast on the coil even though there is one already on the ignition? 63 chevy 230L
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
Yes, it will reduce the firing voltage of the spark plugs to the point you'll get terrible performance under load, a chronic miss, and really lousy gas mileage. If you want to see whether you've got the right voltage to the coil, check the (+) terminal of the coil with the engine running. With a charging system voltage of 14 Volts, the voltage at the coil should be 9.5 to 10 volts. The whole idea behind the reduced ignition primary voltage is to prevent burning the points during normal running, yet allow the coil to fire at full efficiency during starting by bypassing the ballast resistor when the battery voltage is in the 9-10 volt range while the starter is running. If the primary voltage is reduced too much for normal running, the engine simply won't start due to low firing voltage. The same holds true for a 6 Volt system with dirty connections at the coil or the distributor. Plenty of cranking speed, but no fire.
I just replaced all of the wiring in the truck. The aftermarket wiring has a ballast in the ignition wiring. I replaced the coil w/an aftermarket Summit 40,000v and it seems to run fine. Just wanted to make sure that I didn't need an external ballast at the coil. Thanks.
