1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#614802 01/29/2010 8:57 PM
Anyone have a Magna Force air compressor? I believe Sanborn makes them????? model number is g650B60V. Found a used one, but can't find the cfm's @ the psi's. Needing to run the blast cabinet. It's a 60 gallon unit.
The best things in life are FREE!
Here's a Magna Force. This is an 80 but I would guess the 60 is very close.
Bruce
My Trucks
Stuff I Collect
Sounds like someone removed the tag.
The important thing is to get a compressor that can keep up with your air demand.
How much air does the blaster require and that will be the minimum air output from a comp. or you will slowly deplete the air in the tank till you have to stop and let it catch up.
I run my blaster with a 7.5 hp, 80 gal. 2 stage and it keeps up, but it gets a work out and off time is short because of the huge volume of air the blaster needs.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Moderated by  MNSmith
