| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 34 New Guy | | New Guy Joined: May 2008 Posts: 34 | Anyone have a Magna Force air compressor? I believe Sanborn makes them????? model number is g650B60V. Found a used one, but can't find the cfm's @ the psi's. Needing to run the blast cabinet. It's a 60 gallon unit.
The best things in life are FREE!
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Here's a Magna Force. This is an 80 but I would guess the 60 is very close.
Bruce | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Sounds like someone removed the tag. The important thing is to get a compressor that can keep up with your air demand. How much air does the blaster require and that will be the minimum air output from a comp. or you will slowly deplete the air in the tank till you have to stop and let it catch up. I run my blaster with a 7.5 hp, 80 gal. 2 stage and it keeps up, but it gets a work out and off time is short because of the huge volume of air the blaster needs. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
