2 members (Peggy M, crenwelge),
173
Mod | | | Forums66 Topics128,077 Posts1,056,015 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Ok I know I recently asked on the v8 I had and now I am asking for help to ID the engine in my 1953 6400 I should have IDed this engine LONG ago so today I need to try to find out. It is a 6 cyl of course and the number I got from behind the dist is LAS 447301 I see numbers on various sites but I am not seeing any very close to this one and I know you guys know your stuff on this also what was the correct color for this engine?? I understand color is not an easy answer.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | According to this site the LAS engine was for a '53 P/G car. | | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Thanks for the help I looked at that page and wasn't for sure if I read it right so that means this engine was out of a car. I know the engine runs great though it is underpowered when the truck is loaded down. Thanks again for the info. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | You bet! If it truly is a '53 PG motor it is the very first of the full-pressure oiled 235's and should be equipped with hydraulic lifters. Should be a good engine for your truck. As far as I can tell, the PG car motors had the same HP rating as the big-truck 235's had in '53. | | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | I sure appriciate the info. Should I get head numbers? if this is a 235 car engine does that mean it would be a Blue Flame? I am glad to hear this is a suitable truck engine I understand there were a couple more versions of this engine in this same time frame. When I get time I want to pull it out of there and repaint it the entire truck needs a restore for that matter
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Take a close look at the side of the block behind the top of the starter. If it is a '53 powerglide there should be a pair of raised marks cast into the block. They are referred to as "captains bars" and are about 1/8" high, 1/4" wide and 1" long. | | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Ok I looked today and see the two bars in the block by the starter. So this verifies that this is a 235 PG engine? Would this be a Blue Flame? | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | It depends on who's description of a Blue Flame you read. Some Chev historians claim the first Blue Flame appeared on the '53 Corvette. Other's say it began with the first P/G equipped cars with the 235 (1950). I think it's safe to say though that a '53 P/G motor is a Blue Flame. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Thanks again for all the info and links guys. Yes I imagine this engine does have the hyd lifters as it idles very quite. This would sure make a nice engine for a 3100 that is on my wish list. Then I will put a 292 or a 250 if I cannot find a 292 in that 6400  | | |
