1 members (Eileen),
271
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Does anyone know if 65's came with factory cab lights. Mine has the holes where the lights would mount but I didnt know if it was factory or not. Thanks. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Normally a pick-up or 1-Ton did not have them. I believe they were an option only. I'm not sure if you could order them from the factory or not, but you could get them installed by the dealer. Large trucks (2 1/2 Ton and larger) seemed to always have them and I would say that they were standard equipment.
It would be really hard to say if yours are factory or dealer installed or not. The only way to prove if they were owner installed is if they did a poor job and were in the wrong position, but I guess it would be possible for a dealer to do a poor job too.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | The holes in the cab are cut really well and are all identical. If they were cut by someone they did a terrific job. I have never seen cab lights though in any catalog like LMC or others. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | The original style Cab Lights are Yankee 77's. They should still be available new. If you can't find any from a vendor, you should be able to find some by searching online.
BTW, are the positions located as 3 close to each other in the center and 1 on each end positioned on an angle?
| | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Thats awesome. Thats why I like this site. You guys seem to know where to find everything. I guess my internet searching skills need to be honed a little bit. LOL. | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | Yep that's how they are positioned. | | | | | Joined: Nov 2006 Posts: 231 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 231 | Vooda, When ya get it done, how's about some pic's? I'm studying on doing it myself. Thanks, Pete 1963 Chevy C-10 Fleetside 1970 C-30 Dump Truck 2025 Silverado High Country 2500 Diesel 2012 Indian Chief Vintage serial #002 motorcycle 1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The RPO (regular production option) is listed as V75 and is indicated as "Hazard and Marker Lights", from the "Radiator, Bumper, and Miscellaneous Final Assembly Equipment" Equipment Group, pulled from the CHEVROLET Truck Data Book of November 1, 1965. | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | | | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | I put cab lights on my 64 C-30. The hardest part is chasing the wires! I used an old speedometer cable, as they will bend an conform, but you can still "push" on them pretty hard. It was time consuming to say the least, but was worth it! Good luck........ | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I have never seen cab lights though in any catalog like LMC or others. LMC has them: http://www.lmctruck.com/icatalog/cb/full.aspx?Page=89 in their 1967-1972 catalog. A set of five is less than $50.00 bucks. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I have several of the NOS factory Yankee 77 clearance lights, including the NOS boxes, wiring, hardware and installation instructions...if anyone needs any. Tony Smith [email protected]
| | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | I have found a brown wire already installed in some cabs. Reach up around the filler neck area inside of the cab and feel around. Waterproof those lights around the holes you drill in the roof, the gaskets don't seal 100% and lets water in that will rust above the windshield. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The brown wire around the filler neck is the power for the fuel tank sender. The orange and white wires around the filler neck are for the dome light. The power for the cab clearance lights, per the dealer instruction sheet runs up the "A" pillar and connects to the lights in series. | | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | This wire has all the bullet connectors attached and run's across the front of the roof line between the outer and inner panel from the passenger side to the drivers side. From there it travels towards the back of the cab then down the rear post and is bundled up and suspended waiting for a connection to the fuse panel. The roof is not drilled for the lights but the wire is in place. You might try removing the sunvisor on the drivers side and fishing around for the wire. When you drill the large diameter hole for passing the connectors through to connect the lights, fish around between the two panels and you might just find the wiring already in place. | | |
