2 members (TexasA&M48Truck, Nick in Manitou), 124 guests, and 3 robots.
Topics128,083
Posts1,055,967
Members48,430
#61450 06/07/2006 11:40 PM
Junior Member
Junior Member
My starter locked up. What all years will fit my 235? I have converted to 12 volts and have the original automatic...
54 chevy 3100
#61451 06/08/2006 12:05 AM
John,
That is a very tough question to answer. If you have the original Hydra-Matic transmission (with enclosed driveshaft in a 1/2 ton truck), that engine/transmission combination had a starter that was only used for 1.5 years (1954-1955-1st series) and it was 6 volt. With manual transmission trucks that have 12v 235 engines, the flywheel teeth were different from the 6-volt 235s (and 216s) and just about any 12v starter from 1955-1962 (at least) would work.
Do you have a Hydra-Matic transmission (in 1954, it would have an enclosed driveshaft if it was a 3100 1/2 ton model).
Tim
#61452 06/08/2006 12:06 AM
1 Offline
When you converted to 12volts, did you continue to use the 6 volt starter? The 12v. starter has a different ring gear on the flywheel...assuming that you have a manual transmission. I wasn't aware that the pick-up had the powerglide option like the cars. Is that what you mean by "original automatic"?
1950 Fleetline Deluxe
...newly built 1959 235
...dual carbs with Fenton split exhaust
#61453 06/08/2006 2:44 AM
Keep track of the nose piece of your original starter. It will bolt onto a car starter and you will be in business. I used a 6V HydraMatic starter and put a 12V solenoid on it. I was told that the 6V solenoid would work but would be too damaging to the flywheel teeth from hard hitting and did not want to have to find another flywheel.
#61454 06/08/2006 2:58 AM
Junior Member
Junior Member
I was told that in 54 it was the 1st year for an automatic in a chevy pickup, however, the power glide wasn't strong enough so GM used a Olds automatic transmission? Anyway, Reverse is clear down at the bottom and Reverse is also park. it does have an enclosed drive shaft and the starter has 9 teeth? I may just try to have this starter rebuilt to 12 volts if it is possible...
54 chevy 3100
#61455 06/08/2006 4:17 AM
54 was the first year for Hydra in Chev. GMC got it in 53. You are right about the shift positions L to R is N 1-4 1-3 1-2 R which as you mentioned is park when the engine is not running. I converted my 54 to HydraMatic. Tim has an original 54 HydraMatic truck.
#61456 06/08/2006 4:29 AM
1 Offline
That's interesting that they used the Hydramatic. GM lost their 1 million+ square foot hydramatic facility in Livonia, Michigan in 1953. They must have figured out someplace else to build that transmission...and then put it in your truck.
#61457 06/08/2006 12:12 PM
Here is an article about the 1953 Hydra-Matic plant fire. The fire did not seem to have a significant impact on the availability of GMC and Chevrolet truck Hydra-Matics (maybe because the numbers were low or the Hydra-Matic was back in production within about a month and a new plant in production in 3 months?).
#61458 06/09/2006 1:31 AM
Junior Member
Junior Member
Thank you very much for that artical that was interesting. I just bought this truck about a month ago so I have quite a bit to learn...
54 chevy 3100
