0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I have a carb (28AV11) and want to rebuild it. All the passages are sealed with lead plugs, and the rebuild kit does not contain any.
Anyone have a source for lead plugs? Or know of a complete kit with the lead plugs? | | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | Go to any sporting goods department, including Wally World, and pick up a package of split shot fishing weights. Little lead balls, in all sorts of diameters. The split mends itself when you tap it into the hole in the carb. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Why pull them out? Unless a carb is all corroded up a good soak, rinse, & air blast will clean all the passages. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A way back when I was a young sprout, my pop who was an old journyman mechanic taught me to pull the plugs and clean all the passages. Back then when you bought a carb rebuild kit it would have new lead plugs included. Quite often the carb cleaner doesn't get into the corners of deep passages. Much of the time I still try to pull the plugs if it looks like I can't get in to the passage with a pipe cleaner and solvent. I've made up aluminum plates with a taperd hole that I can use to form new plugs. If you drill the hole small then work the bit around to taper the lip some you can make a pretty good tapered plug. A soldering iron will melt enough lead to fill the hole and with it you can shape a fairly good rivet head. A good rap on the table will usually dislodge the plug from the mold. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Do you mean actual lead, or solder? Lead melts at 622° F - my soldering iron won't do much. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've just used solid solder in the past. DG
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | My Weller D650 will melt lead, but solder will work, I would use rosin core instead of acid core solder though. .177 pellets for a pellet gun will work on a Zenith carb. I'm not sure if pellet guns are still around. | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | My Weller D650 will melt lead, but solder will work, I would use rosin core instead of acid core solder though. .177 pellets for a pellet gun will work on a Zenith carb. I'm not sure if pellet guns are still around. Oh yes! They still sell pellet guns. Mine is a squirrel killing machine. bought it after a squirrel did $800 damage to the wiring in my '04 colorado...... I killed about 80 of em' in 1.5 years. just don't let the cops find out.....don't ask
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
