1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Can anybody share some knowledge on the grease cap on the distributor. I read that you should turn it every 1000 miles but dont really know much more than that. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 |
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If it is a screw on cap, it used stuff we called cup grease 50 years ago. It was a chassis lube without waterproof characteristics. Cup grease has not been available for many years, but any chassis grease will work. Put a little in the cap and screw it on. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You're correct, one turn every 1k, it should be filled with chassis grease, don't use the heavy wheel bearing stuff, use the light chassis grease. The old vehicles need a lot more care than what we are used to with todays cars. You should wipe a little light film of grease on the distributor cam also every few thousand miles. The points used to have a phenolic rubbing block which had no self lubricating qualities. The new rubbing blocks are made from a self lubricating material like Delrin that actually lasts longer and requires less care but still a light coat of grease on the cam insures that they won't wear down to soon. Also there should be a small felt pad or wick under the rotor, a few drops of oil on this at the same time lubs the cam also. That's about all there is to it. Just don't over lubricate all that will do is dirty up the insides of your distributor and cause problems with your ignition system. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2010 Posts: 27 Apprentice | | Apprentice Joined: Jan 2010 Posts: 27 | Thanks alot. It sure is nice to be able to get help with all the questions that can come up. The amount of knowledge here is priceless. | | |
