5 members (Otto Skorzeny, Gray_Ghost, Bill Hanlon, fonz8261, klhansen), 83 guests, and 2 robots.
Topics128,060
Posts1,055,833
#613916 01/27/2010 4:01 AM
my new mil truc has 7.5x20 tires i have found a great deal on some 9x20 tires my question is will thay rub on the dule rear if put on the factory rims ???
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
They will probably be a little wider than the the rim manufacturer recommends, but I doubt that there is enough difference for them to rub anything. 50 years it was common practice to put 9's in place of 7.50's for extra load carrying capacity.
Check the Accuride wheel catalog for recommended rim widths and dual spacing for any given tire size. Can be found in this tech tip http://www.stovebolt.com/techtips/wheels/
Also check the literature from the tire manufacturer on those tires.
The above will give you a good idea if it will work by what is recommended.
Then as crenwelge suggest you may get away with it even if not recommended.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
If those rims are are the same as the ones on my military, the rim width is 6.5. I thought that you could only run a 7.50 or 8.25 tire on them? On my truck anyways, their is enough room to stick your hand between the duals. If the rubbing of the tires is only issue, then I think I might look into 9x20's. I thought you couldn't run 9.00 because it bubbles over and affects the integrity of the sidewall.
This is making me think - what size tube would you use?
1937 Chevy (converted to 4x4)
1942 Chevy G506 1.5 ton 4x4
1958 Mack B model (on Chevy 1 ton 4x4 frame)
1969 Dodge Charger
1987 K30 Crewcab
The difference in the sidewall will be hardly noticeable. If you hauled loads every day, it might make some difference. I always made it a practice of using a size smaller tube than the tire...an 8.25 tube in a 9.00 tire. On the original installation, it will make no difference. However if you have a flat and reinstall the tube it will have probably stretched to the point where it will fold. Folds in a tube cause a leak in almost no time. We change our own tires and did for the public as well until the mid 70's. I would venture to say that more flats were caused by folded tubes than by nails.
I don't know how Kosher it was to do...but I remember helping my Dad rob the wheel rings off of a junker on the farm and put one between the duals. He said it was to add width to keep them from picking up too large of a rock (we had great gravel roads).
I don't see the problem as long as you have a long enough stud to do so. It isn't much, but it may be all you need.
I agree 300% with the folded tube issue. That and tires run with too low of pressure and the tube slips...
1946 Chevy 2-Ton
More pix in Flickr
1966 Chevrolet L60
More pix on Flickr
__________________________
Whoa! That can't be right!
