2 members (ronsway, Nick in Manitou), 108 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#613764 01/26/2010 8:01 PM
I need to replace my old steel brake lines. JC has a 7 piece set of preformed SS brake lines for my year truck for $185.00. For the money spent is this the smart way to go? Seems like the ease of assembly would be the big winner, plus not having to figure out all the bends and getting the double lap flaring correct. Who's been successful with installing these preformed SS hydraulic tubing sets and were you satified with the vendor?
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
Why stainless? The regular steel lines have served your truck well all these years and new ones will probably outlast you. As to forming them, it is not a problem. The routing is quite simple.
My 2 cents!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Last time I replaced brake lines I bought steel tube and formed the lines myself.
If you are not comfortable doing that, or don't have the needed time (it didn't take that much) a preformed set could be your answer.
As for stainless over regular steel, if you are forming them yourself the stainless is much harder to get right so I'd stay away from it. But stainless will look nicer longer and probably last longer too, though either is likely to give more then 25 years service.
Its not the cheapest most DIY approach, but I see no reason not to do it if you like the idea.
Hello
I just finished redoing a 58 GMC Panel and I used Classic Tube SS. I did not have any trouble and SS is the way to go.Just be sure to clip it down so it will not rub on any thing this goes with steel tube also hope this helps Sam T
I guess a lot of it depends on how old you are. I have almost a dozen 50+ year old vehicles with original steel brake lines. I am 66 years old and installing brake lines that will lost longer than that is pretty low on my priority list.
I'll be giving my trucks to my offspring many years from now. I have no doubt that regular brake lines can last many, many years. I use stainless steel brake lines and hardware (whenever possible), so that I will rest in peace when I rest in peace.
By the way, I had original 1948-1954 brake lines fail in VA in 1969-1974 (no salt used on the roads back then) but the lines were sometimes corroded from the outside and sometimes from the inside.
ODSS President
ODSS President
I used SS when I replaced my (then 50 year) old lines 12 years ago and they look the same as the day I put them on.
So worth it, IMHO.
~ Cosmo
1949 Chevy Half Ton
I use stainless...
Stainless is Forever
I have made my own stainless lines and while it looks really nice it is difficult to flare and bend and get to fit right, not impossible, but not all that fun.
If you want stainless the pre made kit might be a good choice.
If you want to make your own lines copper nickel alloy brake lines are very easy to flare and bend, look nice and don't corrode. Copper nickel is used by a number of European car manufacturers and seems to be getting more popular here. I've got some for sale here if interested.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
