1 members (RLB),
116
Mod | | | Forums66 Topics128,090 Posts1,056,378 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61338 06/05/2006 6:41 PM | Joined: Mar 2006 Posts: 29 Apprentice | | Apprentice Joined: Mar 2006 Posts: 29 | What is required to swap a 3 spd standard on a 65 Chevy C10 to a TH350 tranny? What were your exreriences? Problems? tips? anything is tremendously appreciated!!!!
How does the crossmember for the ebrake work with an auto tranny? Do I need to get and install another crossmember for the tranny? Or does it use the ebrake crossmember? Does the ebrake set up need to be altered? If so how? | | |
#61339 06/06/2006 12:47 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I didn't do the swap, but I had a 63 C20 with an Olds 350, TH400 and it was all bolt in, From the engine to ebrake cross member. The tranny sat on top of ebrake cross member. The steering was swaped out for a 70 pickup, it should have been shortened and inch or two. The drive shaft was a single piece shaft. Hope that helps.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
#61340 06/06/2006 1:26 AM | Joined: Feb 2004 Posts: 12 New Guy | | New Guy Joined: Feb 2004 Posts: 12 | i put one in a 65 i had to cut the cross member out that the bell housing was bolted to. made a new trans cross member out 2x2 square tubing. i dont think i hooked up e brake. hope this helps.... | | |
#61341 06/07/2006 2:51 AM | Joined: Mar 2006 Posts: 29 Apprentice | | Apprentice Joined: Mar 2006 Posts: 29 | Larry - Did trans mount bolt onto the ebrake crossmember? | | |
#61342 06/07/2006 3:33 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The trans bolted on to the ebrake crossmember. This was a Olds 350, not Chevy. It all bolted, nothing looked anything but GM parts. As I remember there may have been an extension, about 5 inches on the primary brake cable coming from the cab. All the other cables did not appear modified. The cross member could have been moved, maybe.
Larry
