1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | I finally, after a dozen years, put an authentic ignition switch--with backing plate--in my '50 3100. What I can't figure out is what goes around the key tumbler that's sticking through the hole in the dash? It looks unfinished, just the tumbler sticking through the hole, but I can't find any part in any of the parts catalogues (American Classic, Jim Carter's, et al) that address this. Any help? Thanks. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | On My 52 it also just sticks through the hole I think it's because you can put a lamp in the switch bracket and the light will show thru the opening.
Pete | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, the early trucks were kind of crudely put together there. I thought someone had put the wrong ingnition switch in the truck when I first brought it home. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Yup! same with my 51'GMC looks like the bezel is missing. Jimmy | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | It taint Jimmy, just looks that way. DG
