0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#613107 01/25/2010 12:47 AM
Hey Guys -
A little expertise is needed here please. I peeled away and threw out the old carpet this weekend and found an unusual sight. To make a long story short, I have found a very very small leak where the clutch rod goes through the firewall. The rubber boot that should go there is nowhere to be found. Is the rubber boot responsible for keeping the fluid where the fluid is supposed to be? When I push in my clutch, should there always be a small amount of fluid come back that the boot captures and recirculates back onto the rod? Again this is a very small leak but over time has made a very big mess on the floorpan. I thank you in advance for any insight.
Thom Masterson
Bats62Chevy #613136 01/25/2010 1:59 AM
sounds to mee you have a leaking master cylinder if you have a hydraulic clutch,fluid should not escape past the piston,rubber boot is basically a dust cover.You should be noticing this and topping off the master,yes? no?
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
Photobucket pictures
timbuk #613303 01/25/2010 2:56 PM
Riding in the Passing Lane
Tim is correct. If there is any fluid in the boot it is leaking out of the vmaster cyl. They are easy to put a kit in. It's a good idea to do the slave cyl at the same time. These rubber parts get more wear then brakes because there is a lot of movement. On brakes you are mostly applying pressure. The cyls. stay in better condition they don't get a chance to corrode in the active area.
1972 Chevy c10 Cheyenne Super
Thanks for your help guys. I'll give it a go.
Thom Masterson
