6 members (tclederman, TexasJim50, baldeagle, Peggy M, cmayna, 49choptop), 112 guests, and 4 robots.
Topics128,018
Posts1,055,341
Members48,419
#61311 06/04/2006 6:11 AM
Curently, my 64' with the 292, has the original manual brakes, with the single resivor master cylinder. 1) The only access to the intake for vacume, is where the PCV valve connects, can I "T" off of this to the power brake unit? 2) Does the power brake unit have to be for a 292 specificaly, or will one from or for a 350 work o.k.? 3) When I get around to converting the front axle to disc brakes, will that paticluar master cylinder bolt to the power brake unit I would be using for drum brakes? I know I will have to add the proportioning valve at that time also. Thanks!
#61312 06/04/2006 3:12 PM
Riding in the Passing Lane
It,s best not to run it off the pcv line. There should be a plug on the manifold below the carb. Or on arunner near the end of the manifold. The power brake units are the same for any engine. I believe the disc brake MC will fit the same booster.
1972 Chevy c10 Cheyenne Super
#61313 06/05/2006 3:06 AM
Thanks Wrenchbender Ret.
