3 members (TexasA&M48Truck, Peggy M, 1 invisible), 118 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#613014 01/24/2010 7:44 PM
I HAVE A 235 ENGINGE WITH A ONE BARREL ORIGINAL CARB. NO TAG OR ID NUMBERS VISIBLE. IT IS LEAKY AND NEED TO GET A KIT. DOES ANYONE KNOW WHICH CARB CAME STOCK.
THANKS, STEVE
Riding in the Passing Lane
More then likely its a Roch. model B. It has a fat bowl & 4 screws holding the air horn down. They changed them very seldom. You can get a kit by the application.
1972 Chevy c10 Cheyenne Super
I think the Rochester Model B was what came from the factory. As Wrenchbender says, you can ID this by counting the number of machine screws holding the top coverplate onto the bowl casting. Rochester B's have 4 screws, roughly in each "corner."
It is possible that it isn't stock. It might be a Carter YF-type if it has 7 screws holding the coverplate to the bowl casting.
Does it have manual choke? A picture would help. You've got some mighty talented folks scanning these boards- I'm sure they'd be more than happy to help if you provided some info on what you have.
