1 members (JW51),
181
Mod | | | Forums66 Topics128,100 Posts1,056,168 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61272 06/03/2006 2:21 PM | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | On my 250, I have an oil filler cap that is also an oil breather. At the back of the vlave cover, I have a PCV valve installed. Since I have a PCV valve, could I switch to a standard oil cap that doesn't vent?
Drew | | |
#61273 06/03/2006 3:17 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | No. The PVC draws air through the engine crankcase, ect. Even if the breather cap gets pluged or fouled up, the engine will push oil. on engines with sealed cap there is another hose to the air filter housing to permit fresh air to the crankcase.
"It ain't a truck if you can't hose out the cab."
