1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 11 Member | | Member Joined: Aug 2003 Posts: 11 | Trying to get this power steering figured out. PO said power steering gear was no good. Truck has pump on it and gear. The hoses were just taped up out of the way still connected to pump. Unlike the gears I've seen in the shop manual and for sale, my gear has no fittings for the hoses to hook to. Instead there is a fitting that is attached to the end of what looks like a tie-rod! The PO had this all covered up with tape and undercoating.I can't find this part at all in the shop manual. Eveything I've seen in the shop manual shows the 2 hoses running from pump direct to the gear unit. Any ideas?????
1964 Chevy C-10
#6128 08/20/2003 12:34 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i saw one in a junkyard like that,like an early mustang.i used the rez kit to put 1973 c10 power steering on my manual 64.if you don't get an answer here you should try www.chevytalk.com | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | AB64, What you describe and say sounds right for a 65. I just checked my factory manual for 64 and the power cylinder was an add on. My 65 C10 has a mount on the the tie rod for the power cylinder and and a bracket on the frame for the other end. The setup on the 65 looks very similar to the setup on a 77 Vette. I'm missing the power cylinder and control valve. The control valve is on the end of the power cylinder and is where the hoses go. The hoses are specific to where they hook up as one is end and the other out. I'd really like to find the parts for my 65. If some one has an Hollanders and could tell me might iterchange I sure appreciate it.
Regards, Larry 63 C20 dialy driver
I don't own a vehicle that isn't old enough to drink. | | |
