7 members (MRMEROTH11, TUTS 59, Barney1951, Gray_Ghost, Wickedbass, JW51, walter74), 96 guests, and 1 robot.
Topics128,068
Posts1,055,880
Members48,428
I have a 40 Chev. 1/2t pu. It came with the original 216, but the air cleaner is a 6 1/2 dia, 3 1/2 high paper element type. In the front is an air dam with the word "FRONT" stamped on it. I have pictures, but don't know how to put them on here or link them. If someone can help me on how to load the pictures, I'm sure it will help identify the air cleaner. I would like to find another one. Thanks.
Dexter I ca give you instructions to post a link from a site such as Photobucket or webshots but you have to already have pics on their web site...
The example below is from my Photobucket album...
Switch from Quick Reply to Screen " Full Reply Screen "
To create a link use the button " create a link to a web page " the button next to the " Smiles " at the top of the Full Reply Screen...
Click the button and Enter the complete URL for the link you wish to add... Just copy and past it in the box... Click the OK button and the next screen " Now enter the title of the web page you are linking to " box will appear... Give it a name and click OK and your done...
54 Chevy 3104
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Thanks, I hope it works for me, I'm all thumbs with this stuff.
Air Cleaner
Looks like the one in my truck but with the wrong element.
Click
If that is the correct cleaner for your 41, then I guess it could be the original cleaner for my 40, except for the element. I would like to find another one in case I put dual carbs on in the future.
Thanks.
Dexter, this is the air filter/spark arrester from a 1950, 216 but I think they were the same regular production item from 1932 on up.
http://www.pbase.com/dennygraham/under_hood&page=13
You should see a few pictures of the paper element next to the original one. Jon’s filter looks to be copper some were aluminum mesh.
Is there a number on the filter that you have in yours’ (usually embossed into the rubber)? It looks to be a very good fit for that unit
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks for the info. I thought all the early air cleaners were oil bath. I guess I was wrong. I had a 50 PU but don't remember what the air cleaner looked like (old age) That was a few years ago. Guess I need to dig out my pictures. The filter I have has no number on it. I have to push hard to get the threads through the lid. It is a little wide. It needs shaved a little around the rubber edge so it will fit inside the lid better. Thanks everyone for your help.
Dexter,
Are you looking for an original-style element, or a more modern replacement element, or an air cleaner unit that matches yours? Jim Carter sells an original-style reproduction element.
Depending on the carburetor you have, JC might have a matching reproduction unit or used unit. If you call them, ask for Mike (OlTrucks here on Stovebolt.com).
I would like to find a used air cleaner that matches the one I have. The correct element doesn't mean much to me. I was just answering Denny Graham's question about the filter I have. I only want one for in the future if I end up putting a dual carb set up on. I think two of these will clear side by side. So I am looking for a "cheap one". It doesn't look like that is possible. I don't know why since they were used on so many years, there should be plenty of them out there? I'm not into show cars anymore. Too much cost and tired of "experts" at car shows telling me what to do. I junked all of my trophies years ago. I just like to drive them and work on them. Thanks for the contact info. I'll check out JC.
Dexter,
10 years ago those old-style units could be bought used for $10-$15. Now they sometimes sell for $50+ on eBay.
Try a Want Ad in the Swap Meet.
It seems strange that people would pay over $50 for a used air cleaner on Ebay when Jim Carter sells new repops for $64.50. I guess there is some difference that a purist would want to stay original.
Oh Dexter, you just haven't bought enough reproduction parts yet.
Denny G
Denny G
Sandwich, IL
I know there is some bad stuff out there. I used to be into restoring GTO's. It was always better to get NOS if possible. I just don't get into that exacting stuff anymore, but I do want it to fit and look good!
