10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible),
94
Mod | | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | I am going to repaint some panels on my 42 truck and have the choice of acylic, air dry enamel or two pack enamel. I am a qualified tradesman in the construction industry, but have little experience with painting panels and would like to know the pros and cons of these options?
Thanks in advance Wombat | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Beings your down under I'm not going to comment on price, you can pick what fits your budget. If your color choice is a metallic you might want to use a base/ clear because it's easier to get good results,but cost is probably higher. If your choice is a solid color I would suggest single stage acrylic enamel. Straight enamel I would only use on farm machinery and then I don't like it because of it's fast fade out. There really isn't much downside to B/C except the price and you have to paint it twice. Once with color and then the clear. Single stage enamel, paint once and your done, but unless your a great painter metallics are hard to deal with and get a great end result. Their cost is probably less. As with all paints you don't want to breath them, but modern urethanes are real toxic making that a downside. I hope this helps. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | If you plan on or must use an enamel, use acrylic enamel. It's much better than the synthetic enamel. The next step up would be a urathane single stage. The urathane is much more durable.
Frank Cox Cox Custom Cars
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Sep 2007 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 154 | I painted my fire truck with an acrylic urathane single stage. It cost me more money, however it sprayed on real nice and it rubbed out even better. That was a year ago and it still looks great today. I would used the urathane stuff again if a had a good bolt to apply it to. | | | | | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | Thanks for all your replys, i have not herd of these paints. The acylic urathane emanel sounds like the one to use.
What should i ask when i go to the paint supplier? I want to rub back, prime and go with a similar color to the original.
Juniper green? and black guards. The black is no trouble but how do i ask for the juniper green? This is a farm truck that i want to look tidy and presentable, not for 'car shows' etc.
Thanks Wombat
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Hey Mate, Are you in the outback or what. Just kidding around, if you know what I mean. You guys have different names for things down there. Are you talking to a paint supplier that deals with auto paints ? You made the comment, What should I ask for. If you were dealing with an auto paint supplier he should be able to explain the different kinds of paints and how they are to paint with. I say that because that's what we have here. What do you have down there, because it's rather silly of me to answer your questions based on what we deal with up here. Finding that color might be hard unless you have someone who can custom mix paint and go for a color match and get something that's close. Let me know what you have down there and I'll try to answer your questions. Dan
