Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (UtahYork, Woodcmiami, TooMany2count, Rusted Nut, Otto Skorzeny), 105 guests, and 3 robots.
Topics128,281
Posts1,058,479
Members48,490
So I bought a differential for my 1950 truck off a guy on Craigslist. Its the Ford 9 inch style, where it removes from the front (basicly torque tube style but with a normal driveshaft). Anyway, the pinion seal is junk, and when I look the seal up on Napa it lists it for 2-3 different axles.
The only things I know about the truck are that its a 1/2 ton, and supposedly a 1960, however the ring gear says 1962 on it. Gear ratio is 3.90 and the only number on the seal is 3776800 K which comes up with nothing on google. Anybody know which axle this was from?
Edit: Napa lists seals for:
Comments: w/ Spicer/Dana 44 Axle
Comments: 1st Design;w/ H033, H035 Axles
Comments: w/ Spicer/Dana 60, 60-35 Axles;.531" Width
Comments: w/ Spicer/Dana 60, 60-35 Axles;.770" Width
-Nick
1995 BMW 318i
1988 Chevy Silverado 4x4
1967 Camaro
1950 Chevy 3100 pickup
Nick,
Dana axles were available in these trucks, LMC shows them as the posi-trac axle. But if the chunk comes out the front like a Ford 9", then it's not a Dana. It's probably the Eaton axle. I did a little digging and found that pinion seal number on the National seal cross reference. Just had to drop the K at the end. National shows it as a GM seal and crosses it to their 6818. They show that seal to fit '53-'62 with the HO33 and HO35 axle. Hope that helps.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
Quote
So then it looks like the 2nd seal listed on their site is the one I need, the 1st design one. Thanks for your help!
-Nick
1995 BMW 318i
1967 Camaro
