Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 112 guests, and 7 robots.
Topics128,281
Posts1,058,470
Members48,490
#612143 01/21/2010 9:28 PM
Apprentice
Apprentice
I am building a Two ton flatbed with a 1986 292 engine with an Offy intake, 4bbl carb, and headers. It sounds great with 18" exhaust pipes on it! I am planning to keep it as a dual exhaust system with Smithys mufflers. Will it perform alright or should I join them into one muffler?
Mark
Riding in the Passing Lane
Duals for sure. You can run long glasspacks & they are not too loud.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
Thank you Wrenchbender! I know that I will love the sound, I just wanted to see if somone had evidence that performance or mileage would suffer from not having all six cylinders flowing out of one pipe.
Beautiful fleet of trucks by the way. I love '58 Chevy trucks. It is my favorite year from that era.
I am putting a '33 cab on my '53 chassis so this one will look pretty cool.
Mark
The rule for racing L6 was to keep the front and rear cylinder groups separated as long as possible.
A single pipe after that would be harmless, but of course would have to be bigger, clearance problems, etc. 2 × 2" 18 gauge pipes = about 2-3/4", etc.
H Online: Content
On the Austin-Healey 3000 we used to race, there was a split manifold with big pipes back to a single muffler, with two pipes in and out. Just taking the muffler/tailpipe assembly off gave us a tuned-length header for racing. Sounds like it was designed that way, dontcha think? I believe the Jag XKE was set up the same way.
You could check with Speedway out of Nebraska,they should be able to inform you about lenght,diameter,back pressure,and preformance.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Dual exhausts on a straight 6 may or may not make more Horsepower, but you think it does 'cause it sounds so much better
Apprentice
Apprentice
It does sound really good! I installed Smithy's mufflers and she purrs like a kitten. No idea if I will see improved performane since this is the first time I will ride behind this engine. However, I am sure I will like it and that is what counts with Big Bolts.
Mark
