0 members (), 72 guests, and 2 robots.
Topics128,072
Posts1,055,906
Members48,429
Ok guys, I am totally baffled on this one.
235cui 1957 3200, 3 on tree. Dual single barrell rochester carbs, fenton intake and fenton dual exaust. The truck was running great up till this past week. I can do 40,50,60,70MPH no problem. BUT on deceleration (coming off highway) I have bogging followed by major backfire and stall. Cant start immediately after stalling, but wait 10 min, and she fires right up. Its like she is getting flooded out big time. Whats happening??? THANKS
Riding in the Passing Lane
When it stalls look for gas running out the throttle shafts or look down the carb throat & see if gas is running in. You might have too much fuel pump pressure. Most vacuum gauges have A pressure tester on them. It should be 3-4 lbs. If exsesive you need a pressure regulator. Also check the point gap & see if it is opening enough.
1972 Chevy c10 Cheyenne Super
You might also check your carb floats. I had a similar problem and it turned out that one of my floats was sticking open causing the carb to flood and stall the engine.
After fighting with my rochesters for a couple of years I finally bought a couple of carter-webbers. One of the best changes I've made to my truck. These are sweet carbs.
George
could it be that I need a pressure regulator?? How much are these and who sells them??
Also, what about a valve adjustment. its got 2,500 miles on the rebuilt (1yr ago) motor.
thanks
In addition to what the others have said, you might check the ignition timing. You may need to advance it.
Bill Burmeister
I got your private message. The point gap was a long shot but sometimes when the rubbing block wears down the points barely break & can cause all sorts of weird problems, but with elec. ignition that is not the case. A vacuum/ pressure gauge is a handy tool to have especially with dual carbs. They are not expensive. If you get a reading you can tell if excessive pressure is the problem. Like Forme says it could be a float problem. First determine if in fact it is flooding like I described in the first answer.
