2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61191 06/02/2006 12:41 AM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Today I bought a new (reman) water pump for my 50 216 from my local NAPA store. There price was 49.99 exchange. The price was good enough for me and lots cheaper than any of the "old truck vendors" I know of. It came with a one year warranty. When I saw the pump I almost didn't give up my original GM core. This pump was obviously an aftermarket and looked new though it was sold as a reman. It was definitely not an original GM rebuilt. It had a cast/forged machined pulley instead of the stamped steel original. Maybe that's all there is available??? Is there anyone out there that rebuilds original water pumps? :confused:
Professional Novice
#61192 06/02/2006 1:36 AM | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Yuor 216 uses a pump that comes with a pulley?? Must be differnt than any of mine. The only engine i know of the have a pully on the reman are the newer 235"s | | |
#61193 06/02/2006 2:02 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I have replaced water pumps on 216 engines.They all had the pulley pressed on them.I never seen them sold without the pulley.Amazing what you learn everyday. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#61194 06/02/2006 6:41 AM | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | I know you are looking for a cheaper version but ... Patricks is now having his own pumps forged. It is very professionally done .. even has Patricks stamped in the metal. If nothing else at least give them a call and let them know what you are dealing with. Chances are they probably have a solution. | | |
#61195 06/02/2006 12:50 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | I am sure this pump will work. I just don't like it. I know I'm being picky and this is probably similar to any that are available anywhere. My old pump was an original GM casting, maybe the original to this truck. I read in the shop manual the procedure to rebuild them, replace the seal & bearings. I'm just wondering if there is anyone I could send an original to and have them rebuild my pump and send it back? Too late for this one.
Professional Novice
#61196 06/02/2006 1:16 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I'd expect any run of the mill machine shop could rebuild it for you.
Mike Barnes 1950 GMC 1-ton pickup
#61197 06/02/2006 6:45 PM | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | I bought a reman from NAPA about 6 months,GM was casted into.They probably just rebuild what they got.
Gangster whites and straight pipes.....
#61198 06/02/2006 9:44 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | probably right Thanks
Professional Novice
#61199 06/03/2006 5:18 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Take a close look at the diameter of the hub that the fan fits on. The pumps with the cast pulleys I have seen lately have to small of a diameter so the fan will not be centered correctly.
See the USA in your vintage Chevrolet! My Blog | | |
#61200 06/21/2006 5:14 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | update I had a leaking radiator so I had it repaired before I installed the WP. I got back on it last night. Installed radiator and water pump no problem. THEN I looked more closely at the fan. The WP hub was large enough for the fan, perfect fit actually, but the rivets that joint the fan blades together hit the pulley.  :mad: It would not bottom out on the pulley. So I started looking at the rusted fan pretty close (I know, something I should have done before now.) It has a crack near the center hole. Who sells replacement fans? I have another fan that came off of my 58 235 I have disassembled but it is different: it has a smaller center hole and the bolt hole spacing is a smaller circle. It looks almost new so I am guessing it is repop. Do the popular vendors sell fans? and do they fit? :confused: Thanks!
Professional Novice
#61201 06/21/2006 5:31 PM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Chevy Duty lists a fan for the 216 engine. Part 83-405 - $29.95 | | |
#61202 06/21/2006 6:21 PM | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | There is probably some guy out there building a mid-60s 4 door, and he opens the box on his reman water pump and thinks, "Rats! This has a stamped steel pulley! Where's my casting??" | | |
#61203 06/21/2006 7:24 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Thanks Fred. I'm worried that the Chevy Duty fan will have the same problem with the rivets as my original. TxLaTx, you're right, some folks are never satisfied.
Professional Novice
#61204 06/28/2006 12:28 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I purchased a nos water pump.I pulled it out of the box today and cleaned off any oil residue.I primered it this evening and noticed it did not have the gm and casting numbers on it.I talked with the seller and he figures it must be a new old replacement stock pump.It has a T casted close to where the radiator hose hooks up.I turned it over to look inside of it.The gear has gm and casting numbers on it.It all looks new,is this a remanufactured pump ? I'm not to concerned if it has gm and casting numbers.Just curious what i bought ? The seller did gaurantee it and said if it leaks, he will replace it.What's your thoughts ?? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#61205 06/28/2006 4:36 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | It's a long way from you but I had my water pump remanufactured, that is everything new except the casting and pulley in Fresno, Ca. it cost me $65.00, it was bead blasted and looks like a new pump. Definitely the way to go. If interested I can give you name and # of the shop. My e-mail is [email protected] | | |
#61206 06/28/2006 10:39 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Can you post the name and number.I'm sure there are others interested or will be.I have already paid for the pump i got.It looks brand new,just does'nt have the gm casting numbers. I am going to run this pump,it's gauranteed.I do have an original one, i would like to send in sometime. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
