3 members (Donf, Oswald, Bill Hanlon), 133 guests, and 1 robot.
Topics128,042
Posts1,055,519
Members48,424
#611831 01/20/2010 8:26 PM
JRE
Offline
I want to put powersteering in my 62 snb on a 65 chassie.I've got steering box and was told it would be good to put a reinforcment plate on the back side of the frame to keep it from cracking. Is there any place that makes that plate or do I need to make it myself. Thanks Justin
Justin:
I have done this conversion many times. The '60-'62 truck frames are boxed, so doing the conversion is a little more involved, however, since you are doing the conversion on a '65 C10 frame the modification is relatively easier. The power steering conversion brackets are designed to, not only, reinforce the frame rail, due to the additional holes in this area, but also, provide the correct geometry and spacing from the frame rail, to avoid interference. Although there are several kits on the market, I fabricate a kit of 1/4" stainless steel, cut with a water jet and Grade 8 fasteners.
Send me a PM and I can provide this information or you can call me at 913-207-7789 and I will explain the process to you and help you with the necessary parts to do the power steering conversion. Converting your truck to power steering will be one of the best upgrades you can do and I highly recommmend it.
Let me know if I can help. My e-mail address is: [email protected]
JRE
Offline
this is my first Chevy truck but not my first time fixing up a vintage car. I've fone several model a Fords in the past and do automotive typ painting at a metal fab shop. The truck was givin to me by my Cousin due to the fact he lost interest in the truck. I Just got off the phone with him.I miss understud him the last time I talk to him. The Chassie is a 62 has 2" dropped spindels and newer disk brake and 4" dropped springd in the rear. Thanks for the info I'll getting ahold of you soon.
