8 members (tclederman, 68ironhead, 3B, GMCJammer51, Otto Skorzeny, Pre '68 Dave, Jon G, 1 invisible),
124
Mod | | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Since I’ve got the motor and steering gear out, and the entire front clip off the old gal this winter I figured it’s time to finish up the front end work. All that’s left on the suspension/steering now is to clean up/check out the springs and replace the bushings.
Since I don’t have access to a 1/2-ton front spring to compare my 3/4-ton front spring to I’m gonna have to depend on my you, my buddies here on the bolt. I’ve been under the impression that the 3100 and 3600 springs and their mounting were the same. In fact the whole front section of the frame should be the same on both from my past research. In The Filling Station’s catalog I’m looking at the front shackle bushing info and they make no mention of the 3/4-ton in their listing; http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z56330~P6.00~~~~S2UH0FGXW024119617636b~Z5Z5Z5~Z5Z5Z50000014x (sorry bout the hyperlink, cant post a two line link I guess.) The listing for the front spring-rear eye threaded bushing seems fragmented again. It clearly says 3/4 & 1-ton but doesn’t mention the 1/2-ton, which I thought was supposed to be the same as the 3/4-ton.
I want to get the order in today so I’d appreciate hearing about your experience or any feedback you may have.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2005 Posts: 1 New Guy | | New Guy Joined: Dec 2005 Posts: 1 | The front bushing s are different on the 3/4t. They are larger | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Again all I know about is GMC. Front shackle kits for 1/2 and 3/4 ton were the same. 1 ton was different. That was a while kit. Bushings, threaded pins. shackles, cork and zerk. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Got it guys, I pulled it all apart before lunch and yes Ken,after looking in the parts book, they are the same. Front shackles are fine, no wear at all, just need new seals for them, rear bushings and bolts are shot. Got'em ordered already. DG
| | | | | Joined: Mar 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 53 | When I rebuilt my 51 3600 the parts all came from a local spring shop in Quincy, IL. They had current catalogs for the old trucks. They did suggest using a thin section of rubber hose for the new seals. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm gonna stay with the original seals, i.e. cork. I'm going to make up a punch to punch out my own. Denny Graham Sandwich, IL
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I think some of the vendors sell cork seals. | | |
