2 members (Jims46, klhansen),
125
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,995 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 10 New Guy | | New Guy Joined: Mar 2008 Posts: 10 | I just bought this pickup, and I'm planning on putting a 292 into it (from a 1965 C10). My question is this: do I have the the later 3 speed in my Apache that will bolt up to the 292, or do I have the early one? I'm not sure what year they switched. thanks! - Joe
stupid like a fox art and junk: sandiegojoe.com
| | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | All of them will bolt up- - - - -the bellhousing-to-transmission bolt pattern is identical. The Saginaw transmission from the later models just has a synchronized 1st. gear instead of the non-synchronized low/reverse sliding gear of the earlier transmissions. It was first installed in the early 1960's IMHO. If you've got an original-equipment 3-speed, it will have the crash box 1st. gear. To make the 292 engine fit, you'll need to install the 1955-up V-8 bellhousing. Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The trans pattern switched in '47. The existing trans will work fine. You will need a V8 bellhousing ('55-'59) or a V8 or 6 cylinder bellhousing ('63-'72) in order to use the 292 in a '59. Front mounts will have to be fabricated. You will lose the stomp starter.
Bill Burmeister | | | | | Joined: Mar 2008 Posts: 10 New Guy | | New Guy Joined: Mar 2008 Posts: 10 | So, I'll need to find a V8 bell, and replace the clutch assembly. Too bad about the stomp starter, I was digging that.
At least I will not have to mess with the shift linkage.
Cool - thanks for the quick info guys. - Joe
| | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | It's possible to rig a fake stomp starter- - - - -just fabricate some brackets, and put a push button starter switch under the original stomper pedal. The brackets would probably need to mount to the cab floorboard rather than the bellhousing like original, but it's definitely doable. Only a real expert could tell the difference without doing some investigating under the hood. Jerry
| | | | | Joined: Mar 2008 Posts: 10 New Guy | | New Guy Joined: Mar 2008 Posts: 10 | Will the existing clutch work inside the V8 Bell?
| | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | It depends on the bolt spacing on the flywheel. The clutch disc spline will interchange, but not necessarily the pressure plate and/or throwout bearing. The clutch pedal linkage might require some modification, also. Jerry
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy SanDiegoJoe, you should be able to find a flywheel to accept your existing clutch, and all the existing clutch linkage should work without modification, if you find a 55 - 59 V8 bellhousing it should have the smaller slot for the forged throwout arm, which won't look so out of place, the newer bellhousings have a large hole for a stamped out throwout arm, but they will work, they just look odd with a narrow throwout arm in them, hope that helps. | | | | | Joined: Mar 2008 Posts: 10 New Guy | | New Guy Joined: Mar 2008 Posts: 10 |
