| | | Forums66 Topics128,109 Posts1,056,260 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 25 Apprentice | | Apprentice Joined: Nov 2006 Posts: 25 | Does anyone have a template for this trim, as in where to place the holes in the body for the clips? | | | | | Joined: May 2005 Posts: 57 'Bolter | | 'Bolter Joined: May 2005 Posts: 57 | There's a layout for the holes in the assembly manual. Well worth the $30 or so for the manual, if you're going to work on one of these. You can also find new clips for installing the molding, but I don't remember where. I think it's the same as for the standard long bed molding, so most parts dealers(60-66) should have them. Just a tip: When installing the molding, make sure you don't press on the center of the strip, push on the outer edges. Take it from a dummy who dented his! | | | | | Joined: Nov 2006 Posts: 25 Apprentice | | Apprentice Joined: Nov 2006 Posts: 25 | | | |
