| | | Forums66 Topics128,099 Posts1,056,501 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | does anyone have pics of a 63-64-or 65 overdrive governor, or possible have the part for sale. im trying to replace a missing one and was told one of these years is what i should be looking for. one of the last years non syncro od transmission made. i jus wanna make sure im looking for the correct one | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Here are some photos of the overdrive transmission. The photo where the guy is drilling and tapping for a drain plug shows the governor. All of the Warner transmissions used in Ford, Chev, or Mopar used basically the same governor. However on some, the driven gear was a little longer than others. http://www.hydratech.com/pctc/Public_Documents/bwrebuild.pdf The bottom picture that shows the transmission from the rear shows the governor on the passenger side.
| | | | | Joined: Jan 2009 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 121 | All of the Warner transmissions used in Ford, Chev, or Mopar used basically the same governor. However on some, the driven gear was a little longer than others. thats what i origionally thought, but after finding and buying an early non syncro 4 bolt governor.. i found it to not be the correct size. i learned that around 64-65 the governor faced down (fitting issues with the tunnel)was still a cast looking piece with a metal top and smaller threaded portion. now that seems to be what i am looking for | | |
