2 members (3B, Cosmo), 149 guests, and 3 robots.
Topics128,080
Posts1,055,951
Members48,430
#610450 01/16/2010 2:49 AM
Been awhile since I removed the old fuel gauge now its time to install the new one I believe that when looking at the guage when installed in the dash the sending wire was on the left post (E side) and the ignition wire was on the right post (F side)could someone confirm this? Again this is a "54" 3100
Mike
mperk #610496 01/16/2010 5:03 AM
1 Offline
Mperk, If the gauge is installed in the dash and you are looking at it, the drivers side terminal will go to the sending unit. The pass side will be the hot from the ign.
Jeremy
http://s925.photobucket.com/home/jeremy5756/allalbums
The only dumb question... is the question you didn't ask...- Unknown
Thanks Jeremy thats the way I thought I remembered it but as I like to say "I don't remember anything I ever forgot"
mperk #610633 01/16/2010 9:35 PM
1954 3100 Fuel Gauge Wiring:
I just checked three different 1954 gauge clusters and the 1954 wiring diagram:
Sender (brown/black wire) attaches to the post behind "F = Full" (passenger side from under the dash); and,
Power (pink wire) attaches to the post behind "E = Empty" (driver's side from under the dash).
This is confirmed by the red warning tag on the sender post (passenger side under the dash) on all units and 1954 Shop Manual Wiring Diagram (color code).
1953 and earlier might well be different.
tclederman #610648 01/16/2010 10:47 PM
Now I am really confused Jeremy and Tim say just the opposite, does it matter if we are talking 6V or 12V my truck is 12V and I ordered a new 12V gauage????
mperk #610654 01/16/2010 11:21 PM
If it is a 12v 1954 gauge, the orientation would most likely be as I describe for the 6v gauge.
I bet the gauge you receive will have the sender-post marked with a label.
tclederman #610660 01/16/2010 11:36 PM
Just checked my 52 again and the power is on the drivers side and the sender is on the pass. side
Pete
Pete52 #610695 01/17/2010 3:30 AM
Thanks for all the help, I went out in the shop and checked the wiring diagram I had and sure enough sender goes on the pass. side power drivers side
Mike
mperk #635129 04/05/2010 10:04 PM
thanks Tim I'll be sure to switch mine around before I hook up the battery.!
