4 members (Otto Skorzeny, JW51, baldeagle, klhansen), 85 guests, and 3 robots.
Topics128,079
Posts1,056,303
Members48,441
I have a 62 1/2 ton Chevy with a 235 six engine and standard three speed transmission. I have always used 80/90 weight trans grease but in cold weather it is somewhat difficult to shift until the truck warms up. Would changing to a similar weight synthetic grease help? I don't want to cause damage to my transmission !! Thanks for any thoughts. Edabbs
Green Machine
I've been using a 70/30 mix of Lucas 75w140 synthetic and Lucas Oil Stabilizer in my 318/overdive, it's working very well. Shifts just fine in all temps.
Bill Burmeister
If you want easier shifting when cold a 75W-90 GL-4 manual tranny synthetic gear lube will work just fine.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
You can use a tractor transmission oil of whatever viscosity is appropriate for your temp. ISO 46 would work well in the cold. Here is a link showing viscosity conversions.
Stan S.
www.bobistheoilguy.com/visc.html
I use 50W synthetic everything. It is required to preserve the warranty in our Fuller/Eaton and Meritor transmissions and I use it in my old jalopies as well. We have some transmissions with a million miles on them and they still look good.
Stan ISO 46 is hydraulic oil. you would be closer to ISO 260 (SAE 50) or ISO 320 (SAE60). UTF (Universal tractor fluid) is simply mineral based hydraulic oil with viscosity modifiers and is used in everything from the transmission to the hydraulics to the axles on a transmission. It is generally a bit thick for hydraulics and a bit thin for axles and transmissions, however it is intended as a compromise so there is only 1 fluid used for service.
I'm with Crenwelge, Synthetic SAE 50 makes transmissions happy.
