Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 111 guests, and 7 robots.
Topics128,283
Posts1,058,505
Members48,490
After reading about Super55's Manifold Disaster I'm wondering if my plan to remove mine ('57 235) for bead blasting & painting is a bad idea. I would hate to have them crack and have to try and find someone to weld them up. Would I be better off painting them on the engine and wrapping them in tin foil when I paint the engine? I'd like to do the exhaust in black, intake in silver and engine in blue/gray so everything would be different colors.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
Manifolds are taken on and off every day,just take your time and do it with the shop manual instructions it will tell you the right way to remove and install them,just make sure that they are straight before you paint them ,put a straight edge across both of them that way if they are not you can take them to a machine shop and have them ground flat before you paint and try and install if they're not straight they will leak or worse crack when you go to tighten them to the block.
Good luck,Pete
