2 members (sron48, Gray_Ghost),
105
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 7 New Guy | | New Guy Joined: Jan 2010 Posts: 7 | Hi Guys I have a 65 fleetside and the motor has been changed too a 350... have been thru a couple of starters already and have had too shim them... seems the shims that come with the starter are not working just right any suggestions?... Its hard too get the starter in and out because of the headers.
Thanx dawg65 | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If you have the correct starter it should not require shims. Sometimes rebuilders install the incorrect nose and they don't fit right. Check the teeth on the ring gear as they could be damaged and be contributing to the problem. Also some headers cause starters to overheat, you may need to install some kind of insulation material if this is the problem. Fred
| | | | | Joined: Jan 2010 Posts: 7 New Guy | | New Guy Joined: Jan 2010 Posts: 7 | thanks brottha will comply | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Make sure you are getting the HD starter. The HD starter has 2 terms. comeing out of the starter that connect to the selinoid. It will have a spacer between these terms. & selinoid. You may need a sheild over the selinoid &/or the starter. A lot of guys use those small gear reduction starters with headers. I've never used one but the say they are stout. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
