0 members (), 247 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#610004 01/14/2010 4:34 PM
Hi Guys I have a 65 fleetside and the motor has been changed too a 350... have been thru a couple of starters already and have had too shim them... seems the shims that come with the starter are not working just right any suggestions?... Its hard too get the starter in and out because of the headers.
Thanx
dawg65
If you have the correct starter it should not require shims. Sometimes rebuilders install the incorrect nose and they don't fit right. Check the teeth on the ring gear as they could be damaged and be contributing to the problem. Also some headers cause starters to overheat, you may need to install some kind of insulation material if this is the problem.
Fred
thanks brottha will comply
Riding in the Passing Lane
Make sure you are getting the HD starter. The HD starter has 2 terms. comeing out of the starter that connect to the selinoid. It will have a spacer between these terms. & selinoid. You may need a sheild over the selinoid &/or the starter. A lot of guys use those small gear reduction starters with headers. I've never used one but the say they are stout.
1972 Chevy c10 Cheyenne Super
