2 members (msmall, TUTS 59),
45
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Does anyone make the windshield (latches or hooks) to keep window tight for a 46 chevy truck?...Yep took it apart a year ago and lost them...
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I have never seen a "latch" as such. In all the trucks I have seen and 4 I have owned the windshield regulator held it closed at the center. | | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | jd, These latches were on Canadian built trucks only. Your best bet is to search local scrap yards, or perhaps some of our Canuck friends could find some for you. Good Luck. Stan | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | That sucks that you lost them jd. There is a wrecker out in Prince Edward county that I went to 2 years ago, name is Roblin's. He has a lot of old trucks. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Was this the yard? It's a shame, the vehicles are all gone! He had some good ones too. photo's | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | No, it was Roblin's, in south eastern Ontario. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | That's the one all right. I got some hard to find panel parts there. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | GMONIZ, I went through Minakers before the crusher came! I spent a whole afternoon taking photos. That is where I got ny 410 pumpkin.
JDhoward, It is good to see your post. How is the panel treating you these days? The last time I saw it you had only got it the year before.
Fred | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I have seen a few swing windshield pickups with a " cam lock " type latch - I think it might be something you would find at a Marine Supply place - they were stainless steel | | |
