2 members (Brian Moore, J Lucas), 67 guests, and 3 robots.
Topics128,030
Posts1,055,423
Members48,422
#609705 01/13/2010 1:26 PM
Hi. still havn't decided yet on the front end i have a 69 front i will at some point install.. just not yet but anyhow is there any articals "with lots of how to pics" on removing individual leaves from front springs, if only a shop can do that then i might go ahead with the other swap just for cost sake, just first priority is to get it on the road and driving the complex stuff i can always redo later any links would be helpful concerning this subject
1937 1/2 ton
i removed my springs and smoothed them out at home. just clamp the leaves with a c clamp and remove the center bolt. of course the most important part is to support the truck on jack stands before removal of the springs. safety first. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I've not seen any articles on this but have taken springs to pieces and put them back together lots of times.
just knock the spring clips open with a hammer so that they come clear of the edges of the spring leaves. Then put the whole spring in a heavy vise so that the jaws clamp the complete spring right up by the center bolt. When you have the spring clamped tightly, you can undo the nut on the bottom of the center bolt before undoing the vise and releasing the tension on the spring leaves.
Re-assembly is the reverse of the above, it will be a lot easier if you put a long piece of round bar through the hole before you wind the vice jaws back in, this aligns the spring leaves so that you can put the bolt back easily.
Stuart.
cool good tip on the round bar smile
1937 1/2 ton
I have a bunch of leaves around my home. Come on over and bring a rake. yahoo
~Jim
big c-clamp and mechanical common sense. Depending on the vehicle, I have mix and matched and cut springs to change the spring rates.
