1 members (klhansen), 147 guests, and 0 robots.
Topics128,162
Posts1,056,939
Members48,458
#609033 01/11/2010 5:42 AM
Hello,
I am trying to install the oil pressure sensing line in a 235. Only thing is it doesn fit into the case. Is there usual a reducer in the case to allow for the line to fit?
the gauge end? you should be able to find fittings at plumbing suppliers or FLAPS that will fit
All of the Old Chevy truck supply catalogs have these fittings.
I got my reducing fitting at NAPA. It's a common brass fitting.
This might be the fitting:Balkamp part #701-1542
http://www.napaonline.com/Search/Detail.aspx?R=BK_7011542_0006393668
Thanks everyone!
