1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | The front drums on my '52 3100 are riveted to the hubs. The books show a gasket between these two items,and probably the source of my minor grease weep. Were these units ever separated? Must they be rigidly together? I believe they'll work just as well either way. Any thoughts? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I believe all these trucks originally had the drums riveted, but over the years many [even most] have had the rivets removed to replace drums or hubs - not needed .... and that "gasket" is just a piece of paper, not a seal - won't make any difference for keeping grease in, but not using an excess of grease can make a difference, it's common to find waaay too much grease in home maintained trucks .... also make sure the inside seal is sound
Bill | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | If you have a grease weep problem, you need to replace your inner seals. There is a grease shield on the inside that catches any grease weep and directs it out of the brake drum area. There is a hole in the drum and hub that will be lined up to allow any junk to run out of the drum area. There is no reason to separate the hub and drum unless the drum needs to be replaced. In that case they work just fine without being riveted together. Just make sure the grease shield is in place, and the holes are lined up. The shield is held in place by the lug studs. | | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | THank you very much!! You fellow stovebolters have been a tremendous help to me on this project, thanks again!! | | |
