4 members (32Fordpuchoptop, Lightholder's Dad, 2 invisible), 110 guests, and 0 robots.
Topics128,049
Posts1,055,635
#609256 01/12/2010 12:47 AM
Can anybody suggest an inexpensive fuel pressure regulator and guage. I see some on Amazon but the low pressure Spectre model has bad reviews and the Holley one starts at 4.5 and goes to 9-- -too high.Everyone tells me I only want 3-4 lbs for a 2 - 1 bbl rochester setup.makes sense. Thanks
What pump? Are you sure you need a regulator? Stock pumps don't generate much pressure...
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
I've been running the inexpensive Mr. Gasket adjustable fuel pressure regulator on my 235 engine with both the Holley/Weber single and later with the dual Carter/Webers. The Mr. Gasket regulator replaced a faulty Spectre regulator.
Both the H/W and the C/W work well with 3-1/2 psi of fuel pressure.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
I have used the Mr. Gasket regulator with dual Carter-Webers but have removed it, with no deleterious effects.
I did not need (or try) to use a regulator with dual original-equipment Rochesters and had no problems after I adjusted poorly-set float-heights inside the carburetors.
Thanks to a PM from Fla54Chevy3100, a few words above now now spelt correctly - the original words led to a very odd meaning. Thanks, Dave
I'm not sure yet if I will need one. I want to check the pressure on the pump I have. I had a couple pumps lying around and don't know if this one is correct for this motor. It is pumping fuel but possibly too much. I just don't have the nerve to go outside to test it tonight. Too awful cold still here in Fla.
Riding in the Passing Lane
Hey Nes. I have some new pressure regs. I bought at a swap meet awhile back. They are Purolator & are adjustable from 1-5 lbs. I'll send you one with the carb. George
1972 Chevy c10 Cheyenne Super
thanks George. Perfect-----------wes
