| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | Can anybody suggest an inexpensive fuel pressure regulator and guage. I see some on Amazon but the low pressure Spectre model has bad reviews and the Holley one starts at 4.5 and goes to 9-- -too high.Everyone tells me I only want 3-4 lbs for a 2 - 1 bbl rochester setup.makes sense. Thanks | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | What pump? Are you sure you need a regulator? Stock pumps don't generate much pressure... If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I've been running the inexpensive Mr. Gasket adjustable fuel pressure regulator on my 235 engine with both the Holley/Weber single and later with the dual Carter/Webers. The Mr. Gasket regulator replaced a faulty Spectre regulator.
Both the H/W and the C/W work well with 3-1/2 psi of fuel pressure.
Dave | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have used the Mr. Gasket regulator with dual Carter-Webers but have removed it, with no deleterious effects.
I did not need (or try) to use a regulator with dual original-equipment Rochesters and had no problems after I adjusted poorly-set float-heights inside the carburetors.
Thanks to a PM from Fla54Chevy3100, a few words above now now spelt correctly - the original words led to a very odd meaning. Thanks, Dave
| | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | I'm not sure yet if I will need one. I want to check the pressure on the pump I have. I had a couple pumps lying around and don't know if this one is correct for this motor. It is pumping fuel but possibly too much. I just don't have the nerve to go outside to test it tonight. Too awful cold still here in Fla. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Hey Nes. I have some new pressure regs. I bought at a swap meet awhile back. They are Purolator & are adjustable from 1-5 lbs. I'll send you one with the carb. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | thanks George. Perfect-----------wes | | |
