| | | Forums66 Topics128,147 Posts1,056,806 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Hello,
I am trying to install the oil pressure sensing line in a 235. Only thing is it doesn fit into the case. Is there usual a reducer in the case to allow for the line to fit?
Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the gauge end? you should be able to find fittings at plumbing suppliers or FLAPS that will fit
Bill | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | All of the Old Chevy truck supply catalogs have these fittings. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I got my reducing fitting at NAPA. It's a common brass fitting. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | | | |
