0 members (),
125
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 13 New Guy | | New Guy Joined: Feb 2009 Posts: 13 | I have been having trouble finding a replacement oil bath air filter for my 66 c10. the one that is currently on the truck is a K&N and it is so old, the material inside the housing is falling apart. I have been emailing K&N tech back and forth for a while now and they dont have anything that would work. Do you guys know where I can get a replacement oil bath air cleaner?
thanks
Jordan
1950 Chevrolet 3600 runs but needs a lot of tlc its an old farm truck 1966 Chevrolet C-10 3 on the tree, 250c.i. six runs and drives. Needs restore(possibly in the next two years)
| | | | | Joined: Feb 2009 Posts: 13 New Guy | | New Guy Joined: Feb 2009 Posts: 13 | anyone? 21 views and no replies? surely somebody knows something about these type of filters
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | if it's a true oil bath unit why not use oil like it was made to? if it's a paper filter i would take it in to any parts shop and they should be able to find one that will work at least temporarily. my hudson has a wire mesh unit that can be cleaned and reused. i have had other trucks that just used oil and oil only on a oil bath unit. i think oil bath units work well and no need to buy anything except sae 30. i'm sorry, i see k&n all over the place and i know they are suposed to be important or something but i know nothing about them, good luck! | | | | | Joined: Feb 2009 Posts: 13 New Guy | | New Guy Joined: Feb 2009 Posts: 13 | it does have the wire mesh that is incased in a round metal cage that sits in the oil. the mesh is whats falling apart. when I take it out, I can sometimes pull strands of mesh out of the filter. also while speaking of that, is it normal for the filters to loose the oil? I have to add to mine on a regualr basis.
| | | | | Joined: Dec 2009 Posts: 18 New Guy | | New Guy Joined: Dec 2009 Posts: 18 | I have one of those filters too. I also have an sales brochure from 1965, it shows the typical filter, the one with the long air spiggot like on my 62 Invader and my 63 Nova (I used to have).
Is the oil bath filter correct? Luckily my mess is still good. I have an owners glovebox manual coming, maybe it will tell me about how often you need to add as I have never dealt with this before either. My manual otta be here this week or next. I'll post any info | | | | | Joined: Feb 2009 Posts: 13 New Guy | | New Guy Joined: Feb 2009 Posts: 13 | thanks. My oil bath filter is just a round metal piece that sits on top of the carb with a wire mesh insert and it sits in motor oil and then the top goes on that
| | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | i just bought a 62 recently. i had never seen an oil bath filter. the guy at dan's classic auto parts in portland oregon had one on the shelf that he showed me to explain how it works. maybe it'll still be around. i'm guessing you'd have to top em off with oil every once in awhile, as when i checked mine it was bone dry.... | | | | | Joined: Feb 2009 Posts: 13 New Guy | | New Guy Joined: Feb 2009 Posts: 13 | ^^ I agree, mine looses oil. I have to top it off a lot to keep it from going dry.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | JDF1986,
What weight oil are you using in your oil bath ar cleaner? What year is you engine?
The 216/235/261 engines' oil bath air cleaners are supposed to have 50 wt oil. Lighter oil might more easily migrate up and into the carburetor (requiring more frequent addition of oil).
The owners' manuals indicate no set time period between checking the oil bath fluid level and also do not indicate the amount that might have to be added (manuals state interval and amount "As Required""). I have never had an oil bath filter "dry out" if I check it at every oil change.
| | | | | Joined: Feb 2009 Posts: 13 New Guy | | New Guy Joined: Feb 2009 Posts: 13 | I currently use 10w40 oil in it. I will get some 50w and give that a try.
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Oil bath air cleaners were available on the light-duty '60-'66 Chevy/GMC trucks, and more commonly found on the HD Series trucks, ie, C50, C60 & C80. I have had a few and they don't have a seperat filter, just the serrated cage with coarse steel wool/mesh as the filtering media.
I don't currently have one, but I see them from time-to-time on eBay. | | |
