| | | Forums66 Topics128,290 Posts1,058,557 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I thought I would ask the people that know so much more then me. I have a 38 GMC that I am having trouble getting the rubber grommets to work for my gas tank filler neck. What is the proper way to install these rubber grommets.
1938 Gmc 1/2 ton
| | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | I keep a spray bottle filled with dish soap and water, rather heavy on the soap. It makes any type of rubber fitting easier to work into place.
It also works well for checking leaks on natural lines, propane fittings and another suspected vapor leaks.
Ray | | |
