1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 16 New Guy | | New Guy Joined: Nov 2008 Posts: 16 | I am currently working on replacing the wiring harness on my 51 1/2ton. The previous owner added a 6V heater & I want to add a radio as well. I'm using a classic parts of america harness that has no additional circuits for the heater or radio. The heater add on is a rats nest of wires that were all aftermarket. I plan to tie both the heater and radio into the original ignition using my own wire and inline fuses. What is the correct gauge size for this type of application? I realize that adjustments need to be for the fact that it's a 6V heater, and I don't want to overheat the wire by using something that is the wrong gauge. Thanks in advance for the help. -cale 51 chevy 1/2 ton owensboro KY | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think the original gauge was 12. Also, the installation instructions for the radio called for hooking the radio up to the non-switched side of the ignition switch. I would imagine this is because the switch was not rated to take the current of the heater and the radio at the same time. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I thought you took radio power before the switch so you can listen to the mighty radio while waiting for the ferry! Well, for a while. If you get in line to early, you better be parked on a hill.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Nov 2008 Posts: 16 New Guy | | New Guy Joined: Nov 2008 Posts: 16 | If I connect the radio to one of the ammeter posts will I be able to listen to the radio with the ignition off? I didn't mention that I want to be able to use the radio with the ignition off at a local drive in movie theater that broadcasts the sound via FM radio. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If you have a modern radio with FM, it won't draw much current compared to the old tube and chassis originals. I've never seen a 6 volt FM, but I've never looked for one either. If you want originality, I recently saw an old drive in movie speaker with an FM radio built in it at a car show. | | |
