| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | I just bought a 1959 Apache and the throttle cable is not connected. Does anyone have or know where I can find something that show how to connect the manual throttle and choke? | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Hey Gene, Welcome to the Bolt! Glad to see another Task Force owner join us. If you do not already have a Shop Manuel or an Assembly Manuel for your truck then I suggest investing in one soon, they are invaluable in fixing and troubleshooting things. As to your throttle cable, there should be a bracket on your carb, screwed to the top of the Air horn. The bracket will have two clamps on it, one for the choke and one for the throttle. the throttle cable in clamped in there and run to the throttle linkage where it threads through a hole and has a little clamp type screw on it that allows the throttle to still slide up for acceleration.
For some reason I can post the link to the Manuel on Old Car Manuel Project.com for a visual. Hopefully someone will come along with an illustration. Good Luck!
58' 3200 235 3-speed/OD
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I take it this is a 6 cyl. Your carb should have a bracket that the cables hook to. The throttle is vertical & the cable core goes into the hole in the rod with cable stop underneath. The choke cable is horozontal & the core hooks into the connector on the carb with the set screw. This is about the best I can explain it. Maybe someone will come in with photo.s. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Someone has previously linked to a picture. You might find it using search. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Someone has previously linked to a picture. You might find it using search. | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | He probably heard you the first time cletis ...  | | |
